dewme5
First layer vs. extrusion width
I'm printing on a Rostock Max V2.
.5 nozzle, .4 first layer height. extrusion steps are calibrated, Printing a 20mm cube, using 2 bottom layers, and single corkscrew walls.
When extrusion width is left on automatic, the box goes gray, and .60mm is used. However, the measured width ends up being .81mm. So, I adjusted the extrusion multiplier from 100% down to 86%. Now, perfect .60mm walls, but the layers have gaps. I've adjusted infill extrusion width from 100% to 200% with no noticeable change.
How can I keep the .60mm walls, while also getting a great first layer?
The left shows 86%, right 100% extrusion multiplier, leaving .60mm and .81mm walls respectively.
KeyboardWarrior
Re: First layer vs. extrusion width
dewme5 wrote:I'm printing on a Rostock Max V2.
Can you got to File-->Save Factory File and post that?
Also, can you post pictures of the measurements you're using?
Lastly, is the profile you're using based off of the Simplify3D 3.0 profile?
dewme5
KeyboardWarrior wrote:[
The profile is one I found online. The Simplify3d profile was not even close to good results.
Pictures of the measurements I'm using, if I understand what you are asking for correctly. 20mm cube, printed single wall in spiral. The finish looks excellent and adhesion is great.
abs_35_spiral_60wall.factory
(700.99 KiB) Downloaded 218 times
dewme5
I think I have found a portion of the answer I was looking for. Researching through the Slic3r manual, I come across
Extrusion Width is the thickness of a single filament extruded either in free air or above a surface. It's not the distance of two adjacent paths since some overlap will be generally applied in order to get better bonding.
So my biggest issue, was a misunderstanding of what extrusion width actually meant. I followed someones suggestion on dialing in one specific aspect of the settings, which lead me astray.
KeyboardWarrior
dewme5 wrote:I think I have found a portion of the answer I was looking for. Researching through the Slic3r manual, I come across
In Simplify3D Extrusion Width effects your toolpaths. If you have issues with your lines not being connected, then increasing the Extrusion Multiplier is recommended.
