cncmodeller
Duplicate Printing with Multiple Extruders
Hi folks,
Loving the new features I haven't tried them all yet but the "align selected model origins" feature is a god send for re aligning stl files exported from a single model for multiple material or manufacturing process allocation purposes. Its exactly what I wanted when I discussed the topic with your support guys by email, but implemented in a much more efficient manner than I could have ever thought of.
Next question, looking at making multiple small part production more efficient, is there a way to get the second print head to mirror the moves on my primary head so that I can create two small duplicate parts in parallel? I assume it'd just require replicating the moves for the left head to the right, and some form of visualisation and part size / placement management within the front end would be useful to reduce the likelihood of simultaneously printed parts overlapping.
Any thoughts??
Cheers
CNCModeller
KeyboardWarrior
Re: Duplicate Printing with Multiple Extruders
cncmodeller wrote:Hi folks,
Any thoughts??
Cheers
CNCModeller
What you are referring to is called Ditto Printing. It would be enabled on a Firmware level, and then it would just extrude/retract on both extruders whenever one extruder is extruding/retracting. It isn't something that is done through the slicer though, it would need to be a command sent to the printer to enable Ditto Printing, if the printer firmware supports it.
cncmodeller
Thanks for that KeyboardWarrior,
Having checked my Duplicator 4s it has a ditto firmware setting so I'll be giving it a try.
Cheers
CNCModellel
