But when I generate the toolpath, the simplify skips some parts.
I have posted this bug one time and nothing was done. I've seen some other users posting this bug too.
When do you intend to fix that?
I'm tired to have to use the makerware...
Thanks.
Well since there are good arguments for booth solutions, the obvious response is to implement a switch to allow the user to choose the behavior.dkightley wrote:There have been a few threads recently documenting the pros and cons of what S3D does in response to thin walls. Some see it as a deficiency....and some see it as tthe correct action.
Do a search if you want to read up on the topic...
I think this may be the case too... the wall is thinner than the extrusion width. As an experiment, try a manual extrusion width set to half the current width.dewme5 wrote:Is the wall thickness to narrow. If so, they will be disregarded.
It really is not quite the same--more like the exact opposite. CAM programs leave the part "material safe" without a workaround. OTOH, S3d leaves the part with no material...and it is not a default, because you have no option to fudge it through S3d.jimmybuckets wrote:It is a function of just about every CAM software I have ever used. If the tool size it too large then the CAM software won't touch it. You wouldn't want a 1/4" bit cutting out an 1/8" hole. Same thing applies here.
