Hi
Updated to 3.0.1 recently and set my printer (Flashforge Creator Pro) going. I returned to my desk and was startled when the machine made a terrible noise. which originated from the print head colliding withe the clips I use to hold down the print glass surface (used with glue stick). Then I realised the printer was doing its initial purge on the right side of the build table and not the left as it had with version 2.2.2.
I loaded up both 2.2.2 and 3.0.1 and discovered that the initial print scripts between the two versions had changed...
here:
(3.0.1)
G1 X150 Y-70 Z30 F9000 ; move to wait position right hand side of the table
(2.2.2)
G1 X-125 Y-70 Z30 F9000 ; move to wait position off table
and here:
(3.0.1)
G1 X110 Y-70 E25 F300 ; purge nozzle
G1 X120 Y-70 Z0.15 F1200 ; slow wipe
G1 X110 Y-70 Z0.5 F1200 ; lift
(2.2.2)
G1 E25 F300 ; purge nozzle
G1 X-115 Y-70 Z0.15 F1200 ; slow wipe
G1 X-110 Y-70 Z0.5 F1200 ; lift
While it is an easy enough fix at my end, just edit the file and add several "-" in the correct places, I don't know what damage has been done to the print head, as it is now printing off center to the right. I presume when the print head got caught up on the clips it has slipped on the x belt, and I have no idea how to re center the print head.
