There aren't universal best settings for this, as with many things in 3D printing it will depend on your printer, filament, etc.desman wrote:What are the best settings to work with to get the smoothest top and bottom layer.
Setup an extra process for each time you wish to change. Adjust the heights accordingly.Tetraodon wrote:Silly question - can you change your extrusion multiplier for top/bottom layers and not for the rest? I'm finding lots of gaps in the tops of my prints (though haven't messed with the settings much - first time using PLA instead of ABS)
Would that affect the edge perimeters (like the thickness of the walls of the model visually) for those particular layers?dewme5 wrote:Setup an extra process for each time you wish to change. Adjust the heights accordingly.Tetraodon wrote:Silly question - can you change your extrusion multiplier for top/bottom layers and not for the rest? I'm finding lots of gaps in the tops of my prints (though haven't messed with the settings much - first time using PLA instead of ABS)
No. You are manually slicing the model, prior to the automatic handling it.Tetraodon wrote: Would that affect the edge perimeters (like the thickness of the walls of the model visually) for those particular layers?
I may be mistaken, but doesn't this setting also adjust the spacing of the lines accordingly? In other words if you specify 200% width you end up with half as many lines in your base layer, so in theory the amount of overlap (and thus gaps) remains the same.KC_703 wrote: BTW - there is a first layer extrusion width that can be set on the "Layer" tab. This should help you get a smooth/solid bottom.
