I've downloaded the part....and there's fresh air between the arms and the body when I look at it in the preview!!
Edit:
Having looked at the .stl, it's not a straightforward fix. There's only one mesh....so it's not simply a matter of moving the two separate arm meshes so the interlace with the body. The arms are joined by a single line at the top...with a small gap at the bottom.
