haimiko
Robo3D R1 - Autoleveling initiated but not leveling
After upgrading to V3 of S3D I've been having leveling issues with my Robo3D R1. The autoleveling sequence would commence before each print but it's like it ignores the results. As a consequence the printer is printing about 0.4mm above the bed. Any ideas how to fix this?
---- Update found it. Under profiles, G-Code, Global G-code offsets. Set it to -0.35mm and now it's fine.
kaan
Re: Robo3D R1 - Autoleveling initiated but not leveling
I used to get awesome prints with -0.07mm offset - now even -0.12mm prints normally, so much has changed with the V3 ...
Auto levelling works as expected for me tho, on the contrary, it works so well that I can no longer print into the plate for awesome surface finishes
