ClassicGOD
Machine Settings not saved
HI,
Just got S3D and it prints very well.
I decided to create a build platform model for my Printrbot Simple Metal. Everything would be OK if not for one problem - the settings in Tools > Options menu are not saved. Once I click OK I can see the model but exiting the S3D or changing anything in the Process settings resets it back. I don't think this is a correct behavior.
You can find my model here: http://www.thingiverse.com/thing:941680
Printrbot Simple Metal with E3D-v6 hot end
ClassicGOD
Re: Machine Settings not saved
Thanks! I have no idea why I didn't find this thread earlier when searching for the solution.
kusmi
ClassicGOD wrote:HI,
Great! Thanks - hopefully Simplify3D will add your model as default for the Printrbot Simple profile (of course only if you would allow this)
ClassicGOD
kusmi wrote:Great! Thanks - hopefully Simplify3D will add your model as default for the Printrbot Simple profile (of course only if you would allow this)
I would allow this - no problem but my model isn't perfect and I don's know if it's up to S3D standards ;)
