Tttugeman
Gaps in print
Hi all,
I am having trouble with my 3d printer. I have the leapfrog creatr hs and im using simplify 3d with it. everytime i print it seems to be leaving gaps in them.
I have attatched a couple of pictures, i hope someone can help me.
Thankyou
Re: Gaps in print
It looks like you might need more top solid layers (see Layer tab) and also a higher infill percentage to help support those ceilings better.
It's also possible you are under-extruding some, but it's hard to confirm that from your pics
Tttugeman
Re: Gaps in print
Thanks for your reply,
How can i access my extrusion settings so that i am not under extruding?
Re: Gaps in print
I would suggest a little light reading on the forum...starting here: viewtopic.php?f=8&t=2367
Every printer is different in the way that the print settings need to be set for the best finished print.
If you take a browse through this section of the forum, you'll see many asking for advice on how to tweak settings to prevent one thing or another. Again, have a read....and then if you're still confused or stuck, the do ask for assistance. With the increased knowledge you'll have, you'll find answers much easier to follow...
EricPeterson
Re: Gaps in print
The issue with the arch definitely looks like a "too few top layers" problem, but the problem with the Buddha (?) looks like it might be a problem with the geometry or an extrusion glitch. Was it printing sitting up or lying on its back?
Re: Gaps in print
Tttugeman wrote:Thanks for your reply,
Increase the "extrusion multiplier" on the Extruders tab. For example, if the value was previously 1.0 and you make it 1.05, you will be extruding 5% more plastic.
