My printer supports Ditto Print, but I'd really like to see it supported in S3D because there are limitations that simply can't be overcome with the stock ditto print...
Now that said, I don't even know if this is possible... but the part I want to change are extruder settings, I'm printing with two different colors and often I find that one needs a little more extrusion than the other, or slightly different temperatures. For the most part I can work around this by pairing "good" filaments together, but when I need a dozen red and a dozen black of an item, its a bummer to have to print them seperately because there's a 10C delta between the filament adhesion sweet spots...
