PV_Eng wrote:Hi,
I've a new problem with my cubepro profile. Like I said in my last messages, I can extude ABS without issue. But for few days, I have tried to extrude PLA to create support. With the Cubepro software, there is no problem, but with S3D after 5 or 6 mm, the printing stops with the error code F22. Several times I had to disassemble the motor and the extrusion system to clear the clog.
So, I think that my extrusion parameters are not adapted to the PLA. Does anyone has good result with PLA? Which parameters should I use to solve my issue?
Thanks for your answer.
I have had this problem as well. I've narrowed my problems down to the retraction settings.
I dont completely understand the M227/M228 commands, and there are a TON of conflicting posts on other forums about them--most of them pertain to the Cubex, which didn't seem to have as many parameters associated with them.
I would copy the M227/M228 lines from the CUBEPRO software's output and paste them into your profile. I haven't done too much experimentation with how these relate to Simplify's retraction code, but it seems to work enabling retraction but making the retraction a very small amount in software. I can't remember, but it seems to me that if i didn't enable it in software, the M227/M228 commands didn't seem to work either. (too busy to experiment lately)
