If it's in inches in the CAD modeling, will Simplify convert it into MM when I export it?CompoundCarl wrote:Pretty much all 3D printers out there use millimeters and celsius. You can still do everything else in inches, like CAD modeling and all that, but for interfacing with the 3D printer, they all use mm/degC
If it's in inches, your part will be 25.4 times too small, the software does detect this most times and asks you if you'd like to scale the model.MIKET wrote:If it's in inches in the CAD modeling, will Simplify convert it into MM when I export it?CompoundCarl wrote:Pretty much all 3D printers out there use millimeters and celsius. You can still do everything else in inches, like CAD modeling and all that, but for interfacing with the 3D printer, they all use mm/degC
