stewslash
[SOLVED] ff creator pro primes wrong extruder
Hi guys I've just got myself a ff creator pro and purchased simplify 3d as my research came up with this being the best slicer around
However every print i try to do ( i have left ex as default) starts with the right ex putting a line down in the front right corner of the build plate then the left ex puts a really thick line down next to and then goes back on itself getting all stuck to the nozzle , then it moves to the middle of the build plate , starts printing and of course it won't because i have a load of filament stuck to the nozzle any ideas ?
bulid plate it level and prints have been fine with replicator g
Re: ff creator pro
It sounds like you may be using the "both extruders" profile, since the "left extruder only" option doesn't prime the right extruder.
Do you want to post your factory file (just go to file -> save factory file)?
stewslash
Re: ff creator pro
Yep that was my problem , thanks for the reply mate
