BaudR8
Re: S3D on the CraftBot
BenO wrote:Does the crafbot go to home at the end of the print with your profile?
I took a look at the profile (only at the ending g-code section) here's what in the profile and what they do:
G0 F1000 Z195 ; lowering the bed
G0 X0 Y0 ; moves the head to (0,0) location, I'm assuming the home for them, this can be substituted for G28 X0 Y0 if you wish
M104 S0 ; turn off extruder heat
M140 S0 ; turn off bed heat
M106 S0 ; turn accessory fan off
BenO
Thank you. I'll have a deeper look at it.
Scottbee
Sorry for the delay in replying.
As noted, I have X and Y go to "home" at the end of the print... but I run Z "down" to the bottom of the bot to give access for part removal.
I've made some minor changes to this profile since I posted it... but for the most part it's still what I am using.
funbart
I have a working profile for the CraftBot with Simplify3D you can find it here: https://www.craftbot.nl/2015/08/05/635/
I tested it together wit Cura / Craftware / Slic3R / Kisslicer for a specific architectural model. http://www.thingiverse.com/thing:875237
So you can find the profiles for the CraftBot for that slicers as well on my site. https://www.craftbot.nl/category/suppor ... -craftbot/
Bart
ahntlia
I keep getting the error Unsupported command M126
I've downloaded the profiles and none of them is working....
