Sirnicha
"Import Models" causes crash
Hello to all,
the function "Import Models" causes at my machine (WIN7 x64) nearly at all times a program crash (Program isn't responding anymore).
If I call at first the "Open factory file" dialog window, the "Import Models" function works!
My suspicion is that Simplify3D misses the SD Card where I have previously saved the G-Code and ejected it!?
This bug is very bad, because I loose all the modifications I made when I forget to push the factory dialog at first...
Sincerely,
Felix
Re: "Import Models" causes crash
Hmm.. I've never seen this before. Do you want to post a crash report? See here if you don't know how: http://www.cyberlink.com/support/faq-co ... o?id=10449
Have you tried going to Help > Reset All Settings?
