mc0676
Two model, two extruder ... how align object ?
He,
i've a prusa with two extruder and i can print using two colors but mine problem is that i import two stl file and after i need move manually until i align perfectly.
In repetier there is a function that do this automatically.
How i can do this in simplicy ?
Two stl for example:
baase.stl
(210.68 KiB) Downloaded 379 times
mc0676
Re: Two model, two extruder ... how align object ?
And the other stl :)
drago.stl
(210.24 KiB) Downloaded 330 times
Watch this video. It explains everything about it: https://www.youtube.com/watch?v=g1V-5aA03dQ
mc0676
Yes, i allready saw that.
But if u use the align it do not work with my examples attached first.
Can you try ?
I downloaded both the files you attached, imported them into S3D, selected both of them (Ctrl-A), and went to Edit > Align Selected Model Origins. It aligned them perfectly. Are you doing something different?
mc0676
Damn it, in the afternoon i re - try again :(
I only put the cut in the plane (in the bottom).
Thank u for now.
