Hi All,
Could everyone tell me, how can I check (and/or reset) the stepper vaules in Flashforge Dreamer?
I have problems with the followings:
- The head moving is larger than gcode script, therefore it makes 5% bigger size parts (only x,y directions),
- when the machine doing the starting script, running out of hard limit, and makes hard noise
- when I print with dual extruders, they are looks misalignment, however the tool tip distance values looks correct.
Of course, I could resize the models before print, and manually adjust the tip distance in g-code, but I think these steps wont be the resolve the original problem...
Im using the latest firmvare..
Thank you for your help,
Greg
