Hello Everybody.
I built my own MendelMax 1.5 from a kit. (video showing what I have here: https://www.youtube.com/watch?v=pOZJaruzslo other videos on that channel)
(The issues I mention in the video about the Z coupler have been fixed, btw)
As you can see, I've printed quite a bit that's turned out rather well. I bought S3DCreator because I have parts to print that will require rafts and support material & slic3r alone wasn't performing for me.
In the video you can see a fan mount being printed. Here are a few pictures of the same .slt file that I've printed using S3DCreator: http://imgur.com/a/lx0az
The print was made with raft (2 layers) and support turned on. As you can see the second raft layer didn't bridge the first layer in a lot of places, the circles for the holes are very distorted, and when it started laying down the bottom of the part the layer wasn't solid (very "thready")
Here's a pastbin of the generated gcode: http://pastebin.com/JhrKDvt9
For comparison, here's a pastebin of the gcode from slic3r: http://pastebin.com/PWt4xFta
I've printed eight of these fan adapters using Slic3r with no problem.
I read the quickstart guide and faq, but I'm unsure I have taken care of everything I need to to get S3DCreator set up for my machine...
I selected prusa/mendel in the initial setup screen.
Under tools>options>Machine and verified my bed size.(might need to uncheck "flip Y axis there")
Under FFF settings I selected PLA and medium quality.
checked include raft, include support.
Under advanced>extruder I have extrusion diameter at .4mm
all other settings at default except under the "other" tab I set filament diameter to 3.00 mm (which is the size of my filament)
Does anybody have any suggestions as to what I should check or adjust in the software?
Paul
