Yes. Definitely adjust between .9 and 1.0 for the extrusion multiplier. On my machine .02 makes quite a difference.Joaquin Picci wrote:Ok, i will try it. This happens ONLY with PLA.
When i switch to ABS i have the next problem: Top layers is ROUGH. This photo is with 1.00 extrusion multiplier. With 0.9 extrusion multiplier i can see little gaps between lines. So i have to play between 0.9 and 1.0 ?
jimc wrote:solid cubes dont tell you too much. you need to do a thin wall cube. in advanced tab check "merge all outlines into solid model", set infill to 0, top and bottom layers 0. perimeter walls 2. when done measure the thickness of the wall. it should measure 2x your extrusion width setting. if its smaller then our under extruding and need to up your multiplier.
