Here is a Factory FIle of the above part I just made: http://1drv.ms/1LvUQG2
I wanted it to be watertight so I made the part double-walled with each surface made of 4 layers. The bottom is double walled too, and I specified each surface to be made with criss-cross parallel lines.
The part looks solid enough, and the loops look like they are all connected to each other, but when I put water in it some of it leaks through the bottom and gets into the underlying infill spaces. I'm sure that, given enough time, that will leak through the bottom surface.
Apparently I need some different settings for extrusion width, or overlap, or something. I'd certainly appreciate any help from anyone who has made truly watertight parts.
