I currently run Simplify3D on two computers and would like to share settings between the two without having to export/import each time I switch machines.
This is easy with KISSlicer since it saves the settings files to the same directory as the .exe which I have placed in my local Dropbox folder on each machine. When I exit the program on one machine it saves the config files which are then opened on the second machine.
Is there a way to store S3D's config files similarly (on my dropbox or other share drive) so that they are saved/loaded automatically on both machines?
