I did several tests with different parameters (Retraction Distance and Extruder Temperature) to see if I could print a stringless copy of this test part:
All of the results looked pretty much the same:
But if I slice the same part with the same parameters in Craftware the result is far better:
So I am confused about what settings to use with S3D to get stringless prints.
