Rebekah_harper
Cooling tab and wanhao D4S
Hiya everyone,
I added a fan for cooling the part as I had the extra slot on the board.
I found that no matter what I put in the cooling tab it goes 100% every time.
Anything on the tab referring to 100% is turned off.
Any guidance would be great as I get temp errors when using cooling.
Re: Cooling tab and wanhao D4S
Pretty sure the x3g protocol only allows for fan ON or OFF. There is no option to set an intermediate power settings. So if your machine uses x3g, that's the only option you have.
