gmoneyphx
How to increase maximum print speed above 4800 (mm/min)
No matter what I set in the default printing speed the maximum that ends up in the g-code is 4800 mm/min (F4800).
I am aware that an extrusion type machine can't really print at this speed - this is NOT for an extrusion based machine.
Where is this 4800 limit set and how can it be changed?
KeyboardWarrior
Re: How to increase maximum print speed above 4800 (mm/min)
Can you post a factory file, or a screenshot of the Other tab and Cooling tab?
gmoneyphx
As soon as I read "cooling tab" I knew what was wrong. After disabling settings in cooling print speed is back to where I want it.
Thank you.
