jjl
Clear "Resent open files"
Is there a way, from "out-side", to clear the Resent open file list in S3D ??
I have, by failure, tryed to open a non .stl file. This causes a Windows crash when I start S3D.
Thanks in advance
Jens
MikeO
Re: Clear "Resent open files"
You might try deleting or renaming the file S3D is trying to open, it may be able to handle a "file not found" situation OK.
jjl
No, does not Work.
I have tryed to uninstall S3D and then reinstall, but it still remember recent open files.
S3D crash after a few seconds. Screen looks ok, left corner writes "succesfully xxxxxx triangles" and right corner the green Progress bar goes to the right, but after a few seconds Windows crash and the computer restarts.
The problems occurs when I updated OpenOffice. The update file is named xxxxxxxxxxxxxx.stl and when I clicked this file to update OpenOffice, S3D starts up because of the the name of the file (.STL) Since that S3D / Windows crash every time I try to run it
Any ideas on what to do ?
/Jens
just go to Help > Reset All Settings from within S3D
jjl
How to do that ?
S3D crash before I can communicate with the program !!!
How do I make a complete new and fresh install ??
I have tryed to uninstall S3D "completely", but the new install has the same setup as the old one, so the uninstall does not remove all files !!
/JJ
jjl
Hi JoeJ
Your trick works :-)
After I have tryed 3 times, I have to do it very fast before the program crashed, the program started up like after a new install. I typed in my username and password and everything looks fine
Actually my screen looks different, now it shows the build platform of a Replicator 2 (my printer) It did not do that before, and I'm pretty sure that the software was fully updated !!
Thanks for your input.
/JJ
