Stabby
Support for internal corners
Hi everybody
I am quite a newbye of 3d printing and much more newbye of Simplify3d software :D so I'm having some problem in supporting the internal corners of my objects
For example in the following simple part I would like to use a low infill (10-15%) but I am sure the the indicated corner will collapse while printing
https://img.bi/#/oXh55Fd!T0VxowZ3C0eweJ ... LXALhQiOfS
In fact if I go to the preview in that corner the printing will not have any support
https://img.bi/#/WJ32DMY!oxjzAAHeWoRg19 ... zKIf1AEtPN
How can I manage this without using a really high infill?
Thank you in advance
Re: Support for internal corners
Can you attach a factory file (File > Save Factory File)?
Using enough top solid layers will probably fix the problem regardless, but it's always useful to take a look at your exact setup
