M303 E0 S200 C8I've never messed with EEPROM firmware - how do I go about doing that?pixel3design wrote:You got just one problem.
TEMPERATURE.
I could bet that your printer PID is wrong and need to be recalibrated.
Look at the Z. The problem is cyclic, means that hotend reach the terminal temperature, then it became too cold to extrude correctly at the given speed.
Recalibrate the PID with:
When calculated store it in the firmware EEPROMCode: Select all
M303 E0 S200 C8
