Tiger91
Unwanted lines on box
Whenever I print a large box, I get slight imperfections in the form of bumps on the front/back, which is in the same plane as the infill lines. I've attached a few photos and documents for reference. What causes this and how do I fix it?
Bumpy box.odt
(306.85 KiB) Downloaded 160 times
Re: Unwanted lines on box
Thats looks more like a hardware issue. excess play in the axis giving the issue.
Tetraodon
Problems in the extrusion feed can do this (eg spools not turning smoothly, or wrong temperatures) - generally if it doesn't show on the GCode preview, then it isn't caused by the software, and is instead a mechanical or filament issue.
pixel3design
You got just one problem.
TEMPERATURE.
I could bet that your printer PID is wrong and need to be recalibrated.
Look at the Z. The problem is cyclic, means that hotend reach the terminal temperature, then it became too cold to extrude correctly at the given speed.
Recalibrate the PID with:
Code: Select all
M303 E0 S200 C8
When calculated store it in the firmware EEPROM
Io non credo in un Dio personale, non l'ho mai negato e anzi l'ho espresso chiaramente. Se c'è qualcosa in me che può essere definito religioso, quella è la sconfinata ammirazione per la struttura del mondo così come la scienza può rivelarcela.
E.Albert
Tiger91
pixel3design wrote:You got just one problem.
TEMPERATURE.
Code: Select all
M303 E0 S200 C8
I've never messed with EEPROM firmware - how do I go about doing that?
