erniehatt
Rafts
I have just printed a fairly large model and decided to use a raft, but I cannot get the model to release from the Raft.
Probably due to some setting I have made, what setting are a good starting point. Also where can I locate the Brim settings. :? Ernie
Re: Rafts
Increase the raft "separation distance". Larger values will make the raft separate easier.
erniehatt
Re: Rafts
Thanks Joel
KC_703
Re: Rafts
Set the "Skirt Offset from the Part" to 0.00 for a Brim.
Re: Rafts
Yup, a brim would be a good option too. If you're new to this, there's a great tutorial about all of these options here: https://www.simplify3d.com/support/tuto ... and-brims/
magicwiser
Re: Rafts
JoeJ wrote:Increase the raft "separation distance". Larger values will make the raft separate easier.
Be careful though because if your value is too big it will warp and separate mid print. After a lot of tinkering, 0.20 seems to work well for me. However, if it is going to be a large print sometimes I will lower it a bit just to make sure it stays together.
