I'm using hatchbox 1.75mm - it got good reviews on Amazon.KC_703 wrote:Post a pic of the results... what filament type are you using?
Below: the two on the left were from S3D, the right was MatterControl
My question is why a $150 dollar program fails while free software works fine?billyd wrote:Printing small parts is extremely challenging.
Use a smaller diameter nozzle if you can.
You've obviously not read my last post! S3d does not fail! It slices in a different way. The item you're trying to print is not compatible with S3D when using a 0.4mm nozzle. And your other slicer is "fudging" the item to make it print.....by thickening the areas that are thin.My question is why a $150 dollar program fails while free software works fine?
That works very well for me! How exactly did you change the settings to make it print well?JoeJ wrote:You said you have a Robo3D printer. Have you tried using the Robo3D profile already built into the software? You have quite a few differences in your settings, most of which will probably have a negative influence on this small print. Did you create this profile yourself?
As many people have mentioned, you are trying to print a very small part, and right now your settings in S3D are not setup for that. After correcting several settings, I printed the attached gcode file on my printer, and the result looked great.
I've read a about the settings tabs in your post - I came across that a few weeks ago. While helpful, it would be more effective if the author put concrete examples of .stl file prints that benefit from the tweaks mentioned in his post.dkightley wrote: This is not the only issue you are experiencing. To get accurate and consistent prints, you need to get the right mix of parameters that suit your machine, the part you're trying to print, and the material you're printing with. Getting this right is not simply a matter of tweaking one setting....but is likely to be adjustments to several parameters, carried out one at a time to see how they affect the print. And to do this, you will need some appreciation of what the settings actually do...and the first step would be to have a read through the threads that describe the settings in each of the tabs. Start here: viewtopic.php?f=8&t=2367
S3D, when you have it tuned to your printer, will give some superb results....and taking the time to read up on the settings will bear excellent fruit. So, don't lose heart......have a read and learn how to get the best out of your printer......
I may be a novice, but I'm trying to learn. That's why I'm asking how to change the settings so the part can print well.billyd wrote:S3D is better suited for advanced users. Its flexibility is also what makes it a little more complicated. It is extremely powerful, but you must understand the settings and what each of them does. Otherwise its power is wasted, and just makes it more frustrating for the novice.
