Hello I have a dual extruder on a Taz 5 and no matter what I set my tool 1 offset to, it never changes anything during the actual print. I've tried stock setting of 53 mm (I think it was 53, but it may have been slightly different) in Y and I've tried changing it during alignment calibration but the print out never changes. My second color (tool 1) is not aligned in Y properly regardless of what I set tool offet for tool 1 to. And it is always off by the same amount, so the tool1 offset is clearly being ignored.
I've attached a factory file of what I am trying to print. On my printer tool 1 needs to be adjusted about 2mm from where it is (in Y) to be aligned properly. But like I said nothing I change in tool offset (under the gcode tab) seems to have any effect on the actual printout.
Am I doing something wrong? In the old versions that didn't support dual extruders on the Taz I used to get it to work using global offset and two different processes. That worked fine but the preview would of course look strange.
