So I did some analysis on the STL and I think I at least have the reason for the missing feature nailed down. Let me make a few general suggestions first, just to help others that might be learning.
Anytime you have issues with a model, the first thing I would do is go to Repair > Identify Non-Manifold Edges. This will analyze the model for any incorrectly formed elements that may cause issues with the slicer. There are also a few tools to help repair problems you might run into, but knowing they exist is the first step. Your model actually checks out fine, so no problem there.
The next thing I did was dig a bit deeper into the actual location where the slicer was having problems. It's clearly a very thin feature, so that can be difficult when you try to represent it with a finite extrusion width. Typically, if the slicer can't outline the region without going outside the bounds of the part, it won't print it. In other words, it will never be able to print a 0.1mm thick wall with 0.3mm wide filament. Just to prove that's what was causing the issue, I went in and decreased the extrusion width slightly so that the very thin feature could now be represented properly (see screenshot).
- smallFeature.png (112.84 KiB) Viewed 8819 times
Now after all this, I would still make one other suggestion about how you're going about preparing these models. Creator includes a fairly advanced interface for adding support material to your models. We're trying to make it easy enough that you won't need to go into a CAD package to add supports manually (like you're probably used to in other programs). If you have trouble with these thin supports you are making in your CAD package, I might suggest playing with Creator's integrated support tools (Tools > Manually Define Support for Model). You could even just turn on automatic support material generation in your FFF profile and that would have solved this problem too.
There's more than one way to skin a cat
