checktest
Add Fusematic Printer
Please add support / default profile for the Fusematic printer from Maker's Tool Works.
Re: Add Fusematic Printer
The fusematic is already compatible with the software. It uses standard Marlin firmware. Just go to Help > Configuration Assistant, select Other and choose the Marlin firmware during setup.
checktest
Thanks for the response. I know it is compatible, as I'm using it currently w/ S3D. Just would like to have a default profile that loads for the Fusematic printer. For example, modified retraction, and other settings that are significantly different than the default settings found when using the "Other" printer selection.
I'm assuming that's the type of customization that printers on this list (https://www.simplify3d.com/software/supported-printers/) have?
