I didn't found a option export my process settings into file/paper. I think it would be great to print settings and then you can print those into paper, and place your part in top of it. Change settings and do it for the another part. This way it would be much easier to compare results.
Comparing two sets of settings is actually quite easy to do.
Search for on Google (or similar search engine) for a file comparison utility called either Winmerge (for Windows) or Filemerge (for Apple) and download & install (they're both free utilities).
Use the Export feature in S3D to export the two settings profiles and then use the above utility to compare the files...which will have been written as .fff suffix files, Both utilities look very much the same.....differing lines are highlighted so you can easily compare them, and the file is self-documenting, so you can easily see what setting is what.
