Ok, Im a newbie here, and have some issues with printing this logo plate. Total width of the part is 60mm, so you get scale right. I have a Leapfrog Creatr XL in my use with dualhead extruder. But as you can see, its not a perfect print. But here's two things that concerns me.
1. The black ABS around the fixation holes is 'messy'
2. The blue ABS could be filled better.
3. Sometimes the material from other extruder messes with the other.
So any suqqestion for my settings to improve this print?
Some settings I used:
Nozzle diam = 0,35mm
Extrusion widh = 0,4mm
Retraction dist = 1mm
Layer height 0,25mm
Top solid layers = 5
Bottom solid layers =3
Outline/Perimeter shells = 4
Outline direction = inside-out
Infill = 20%
Outline Overlap = 15%
Both extruder temp = 235c
Cooling = 0
Default speed = 30mm/s
Ask if I missed something...
