guitartoys
Powerspec Arm representation off, and print off center
Hello, I'm pretty sure this is a new problem with the most recent version.
I'm using a Powerspec 3D Pro (dual head), and have that selected.
In the earlier version, I just saw the build plate represented, with the model on it.
Now in 3.0.2, I see what looks like the Z-Arm. But the Arm looks weird. I switch to the FFCreator Pro, and the Z-Arm looks right.
When using the Powerspec, the model seems to be shifted forward.
I just reverted to the FFCreator Pro, and will give that a try.
But the Powerspec graphical arm needs to look like FFCrator Pro.
You might also want to look at your print offsets.
Re: Powerspec Arm representation off, and print off center
Can you post a screenshot?
guitartoys
I'll get one to you shortly.
Looks like you don't allow uploads to images, but want a link. I'll sort that out shortly.
Oh, and the start up procedures are different.
The FFCP draws a line across the front of the bed, and the Powerspec used to do that too. Now the Powerspec is doing a blob off of the corner, but as I'm using the left nozzle, it's still trying to go off the right corner. So it plasters a blob on the bed. When using the right nozzle it did a blob off the right corner, and when using the left nozzle, if did a blob off the left corner. Looks like you have it doing the blob off of the right corner, regardless of nozzle.
M
I'm not sure who you're talking to when you say "you", but I'm just using the stock profile as provided by the S3D guys. It's working fine.
Of course, you can always go the Scripts tab and edit the starting script to do whatever you want. If you like what another printer does better, then you can copy some of that starting script. You can customize it however you want.
