So when I go to print an object like this Minion (see below) what happens is that it prints very well until it starts the lower spherical shape.
What I think is happening is that its assuming that each lower abdomen layer is "Bottom Solid Layer" and adding that amount of layers, in my case I had 3. So it would make the feet bottoms 3 solid layers do great and then hit the abdomen and do the same for each layer on the overhang sections. This added so much material that it was curling and would just mush the plastic around, almost like wiping the inside of a mayo jar with a spatula.
To alleviate most of the issue i set bottom solid layers to 1, much better but still not great....
My Makerbot at work prints this fantastic.... getting worried that I should have gone that route.
