studiodyne
Software bugs to fix please
***************** BUGS **********************
* BUG : in dual extrusion , the manual generation isn't working for the second color , for example i make manual support for color 1 and manual supports for color 2 , the software make automatic generation and don't want my manual design for the other extruder
*BUG , impossible to make a total pillar in manual support generator when touching bed , it's only possible if you are a little higher ???? BIG BUG
* When concentric solid layer , don't make paralell support , it's unneeded and this will make print in the void !
* BUG of the LAYER DOUBLING !
You have doubled the number of layer by adding a new layer for pillars , dual ex , of ozze shield ,ALL IN THE SAME Z AXIS , so two half layers in one , and the problem is when we select ‘ REDUCE SPEED WHEN TIME IS LESS THEN 15 SECONDS in the cooling tab ‘ , the layer without shield is reduced of speed and the second part is printed 100% speed , and we have two speed alternatively , just because the total layer is divided in half layers … The total layer is more than 15 sec but , just because divided in two half parts , we have two speed for the same Z AXIS or true layer
C-line
Re: Software bugs to fix please
Agree that the print speed of the ooze shield should not vary from layer to layer due to the interaction with the cooling speed overrides. This results in a LOT of wasted time as the ooze shield is printed too slowly on every other layer.
