Ok, I have this issue when printing ABS parts (havent tried other materials yet). But when Im printin overhang, the part edges are much higher than extruder itself. And this is caused most probably (on my opinion) because the ABS shrinks and it is pulled toward the middle. Here's couple photos and video to show the problem:
https://vid.me/yH8Q
In the video you can see how the extruder actually pushes the part edges when printing. And this especially very bad problem when printing wider than 34mm parts because when the edges of the parts rise, the second extruder collides with the part.
What would be the best solution to solve this? Use support to prevent edges to rise? Can the supports in S3D be angled? So they don't come straing up? I have tried cooling to fix this but it didn't help as I hoped.
Is it good thing to add manual supports into my designed 3D part? See the attached picture. The blue part is meant to be support, and if I use circular patter to make those about 10 around the part?
