danielhenley
My feature requests
I've been using simplify for a while now, here are my suggestions:
1) Duplicating a group should result in another group(s) not a bunch of ungrouped objects as it does now.
2) The cross-section feature should aid in selecting objects. Currently if an object is obscured by another it is unselectable in the 3d viewport, even if the cross-section is used to reveal it.
3) Option for a solid first layer under supports to aid adhesion.
4) the rotate manipulator should allow for rotation in all axis, not just z (nevermind, this feature exists, just not default behavior)
Re: My feature requests
For #4, if you want to rotate in the X and Y axes as well, you just need to turn on the full 3D gizmo option. This video explains how to do it: https://www.youtube.com/watch?v=moMR90DmzD4
danielhenley
JoeJ wrote:For #4, if you want to rotate in the X and Y axes as well, you just need to turn on the full 3D gizmo option. This video explains how to do it: https://www.youtube.com/watch?v=moMR90DmzD4
Thanks! I thought I remember seeing that before I purchased and have wondered why it was missing.
