tonyvan22
Taz 5 Dual Extruder Fan Control
I have a Lulzbot Taz 5 with the 0.5 mm Dual Extruder.
I have the Dually Cooly 10 installed for dual extruder cooling.
https://forum.lulzbot.com/viewtopic.php?t=1381
In S3D, when I set any per layer fan controls, it seems to only be applying them to the rear extruder fan.
To control Fan 1 use (rear)
M106 Sxxx
And to control Fan 2 use (front)
M106 P1 Sxxx
Is there any way to get S3D to also control the front extruder fan?
I can bring up the machine control panel while doing a print over usb, and send M106 P1 Sxxx.
But I would like to be able to do it in S3D with per layer controls.
Re: Taz 5 Dual Extruder Fan Control
If it were me, I would just add the following to the "additional commands for post-processing" section on the Scripts tab
{REPLACE "M106 S0" "M106 S0\nM106 P1 S0"}
{REPLACE "M106 S255" "M106 S0\nM106 P1 S255"}
If you are using other setpoints besides full power (S255) and off (S0), just make sure to add those lines. Then S3D will automatically add the commands for you :D
tonyvan22
Thanks!
I will try that and report back.
Would it be possible to add something in the firmware configuration window under Fan Speed Control?
Fan Speed Control
Fan Speed Control
tonyvan22
Carl,
Thanks for your reply.
I'm just reporting back in case anyone else stumbles across this post looking for an answer.
I tried it and it works perfectly!
