Hello,
I am a new user of S3D and like the software but now have run several times into retraction issues, that I am not used to have with Slic3r and Cura, as they do not seem to retract that often (when I compare gcode files with the S3D preview window).
At this point in time I can see all retraction points that are marked in the preview window directly into my print as small or large blobs.
I read that this could be solved by optimizing the retraction/ oozing settings .
For the moment I have translated my Slic3r and Cura into S3D settings but there are several other parameters that effect retraction.
As I saw some posts of other E3D users on the forum, I was wondering if some would like to share there settings and give me a quick start.
I do not expect that someone elses settings will immediately solve my issues, as there will be an machine and filament factor involved as well, but it for sure will point me in the right direction.
My setup:
K8200
3mm Wades direct drive extruder
E3Dv6 with 0.4 mm nozzle
Thanks in advance,
Best Regards,
Robin
