Hi there,
I just start printing with Simplify and GCODE programming, I hope, the question is not too dumb.
As my printer (Cartesio E) is not listed, I wrote some custom g-code Pre and Postfix, which work fine. The machine has two extruders. And there comes my problem:
I want to print with extruder #2 only for now. Offsets and temperature set as they should on machine start. When starting to print, unfortunatly it does not start the filament drive #2 (not sure if it instead drives in Extruder #1). So, the extruder is hot, but nothing comes out of the nozzle.
I also do not find a M6 Command (or anything else which would tell the machine to change the extruder drive to #2).
Would be great to get some input on what I am doing wrong...
