soulhuntre
Printrbot Metal Plus Dual - Bed Centering / Size
Hey all!
So if I put an object into S3D and :center and arrange" using the default settings in the "Printrbot Metal Plus Dual with HBP" profile, using the Tool0 extruder (the default one) the print is NOT centered on the plate - it is to the left (as you look at the machine from the front) by a solid few inches.
Also, S3D lists the bed as 250x250x250mm but Printrbot seems to claim 196x250x250?
So, what settings are you folks actually using?
Ken
Re: Printrbot Metal Plus Dual - Bed Centering / Size
You can always measure it on your printer to be sure ;)
