S3D slices the object in a way that under the rib there is an empty space. This issue does not occur in Cura.
This problem makes parts much weaker, as I use ribs for making the part more rigid an the bond between flat surface and the rib is weak.
My setting are (relevant ones):
-Infill 100%, rectilinear, 40% overlap, print every layer, minimum length 0
-Layer .1 mm
-Outline 2
-Extrusion width .4 mm
Why is this happening? How is this 100% infill if there are gaps in the worst possible places? Did I miss some important setting?
