Q*bert
Re: Feedback and Requests
Simplify3D wrote:Found it! We were messing with a lot of settings so some of them don't look so great. But check out the pyramid on the far right. That was literally one of the best calibration pyramids I have ever seen.
Could you post your settings for the pyramid on the right? I'd like to replicate (no pun intended!)
slipshine
I am not sure if the software does it but if you could get it to output in incrimental instead of absolute
it should get around your problem.
Simplify3D
Site Admin
I'm not sure I have the exact settings for that pyramid since that was awhile ago, but they weren't far off from the default M2 settings that are in Creator right now.
One tip for you in the future, you can actually import a .gcode file into your FFF settings window since it contains every single setting used to create the part. That means as long as you keep the .gcode file, you already have a copy of the exact settings you used to make it :) It's been very useful for us as we try to remember what parameter we tweaked for a specific print
