Hello folks, I've been using cura+repetier+marlin with great results, however now I have to print complex models that require features that cura doenst have.
Problem: I have to print some of my models with NO infil for cost concerns, but they have various overhanging top sections near the middle of the model that will be printed in the void if no infill.
There are at least 3 solutions to this:
1) Internal support for internal overhangs creation: This would be AMAZING, but it seems NO SLICER support this. Im not talking about external support, but support inside the model for top surfaces that would be printed in the void otherwise.
2) Slice the model into multiple pieces (not optimal because visible seams and only works for perfectly flat top surfaces)
3) variable infil with higher density near the top areas.
To my knowledge, S3D might do solution 3, but since THERE'S NO DEMO, I have to bother you guys with detailed explanations about this feature.
Can S3d fill my model like this: 3% sparse infill in the bottom section + 15% sparse near the middle+ 0% in the upper part?
If so, does it create solid tops in the interface between the infil regions?
Thanks in advance!
