berthil
Single outline for the hole model
Hi. Is there a way i can use a layer with a single outline for the hole model without the usage of vase mode?
Im asking because i noticed tha vase mode is useful when the model doesnt have gaps.
I tryed to use 1 outline layer instead, but it prints the layer and then it print it again at the same position on the way back before go to the next layer.
I tryed diferent options but none made it. Then i tryed it on slic3r and it works, but i want to keep using S3D.
Re: Single outline for the hole model
Can you post your factory file (File > Save Factory File) and a screenshot of what you're trying to do? I'm not sure I understand your wording...
