Parameters are:
Bottle model, about 240mm high, printed in 1 perimeter with 1.2mm nozzle, 20mm/s, 0.4mm Layers, but the problem also occurs elsewhere (more perimeters, smaller nozzle, smaller layer height etc.):
The part is printed with 3 bottom layers and 3 top layers, no infill, no support.
The part prints fine, retractions work fine with speed and temperature.
At some points (very small overhangs) in the middle of the bottle, simplify adds very small top and bottom layers, strange enough, but it does not bother me. But every time, after these small bottom/top layers are printed and the nozzle prints the next regular perimeter, it misses out the first 4-6mm and results in a strong gap (see pic below). I tried all retractions settings, nothing solves the problem. All normal travels between islands (there are several travels in the model) or layer change retractions work fine, as said. The problem only occurs after printing bottom/top layers.
Any ideas?
