paulstemmett
Printing cylinder with supports comes out messy
Hi all, first post.
I'm having trouble printing a cylinder so that it comes out fine. It has supports, but where the supports link up to the cylinder, there is a rough pattern and it prints poorly.
I am using a Wanhao Duplicator i3 with PLA filament.
Here are my Simplify3D settings:
Extruder Overview:
Nozzle Diameter: 0.35mm
Extrusion Multiplier: 0.95mm
Extrusion Width: 0.42mm
Ooze Control:
Retraction Distance: 2mm
Retraction Speed: 3800mm/min
Layer Settings:
Primary Layer Height: 0.15mm
Top Solid Layers: 3
Bottom Solid Layers: 3
Outline/Perimeter Shells: 2
First Layer Settings:
First Layer Height: 90%
First Layer Width: 100%
First Layer Speed: 35%
Infill General:
Internal Fill Pattern: Grid
External Fill Pattern: Rectilinear
Interior Fill Percentage: 20%
Outline Overlap: 15%
Infill Extrusion Width: 100%
Minimum Infill Length: 5mm
Support Material Generation:
Support Infill Percentage: 30%
Extra Inflation Distance: 0mm
Dense Support Layers: 0
Separation From Part:
Horizontal Offset From Part: 0.3mm
Upper Vertical Separation Layers: 1
Lower Vertical Separation Layers: 1
Automatic Placement:
Support Type: Normal
Support Pillar Resolution: 4mm
Links to photos of finished product:
https://www.dropbox.com/s/c8kri88gwyfur ... 1.jpg?dl=0
https://www.dropbox.com/s/389uojtuaci5d ... 2.jpg?dl=0
Link to preview of my supports:
https://www.dropbox.com/s/kutimrhu577tn ... D.jpg?dl=0
Link to STL file used:
https://www.dropbox.com/s/rgdafsuix0jri ... 5.stl?dl=0
Any assistance as to what settings I need to adjust in Simplify3D will be greatly appreciated!
